plz plz help me plz
plz plz help me plz
hi everyone
i feel very humilliated by this but knot nowing that the throttle linkage came lose i started my rush up and it whent to full throttle and i could not turn the engine off for about 20-30 seconds. this ment the engine was cold and started too full throttle. what do you think i should do about the engine?
IS IT SCRAP,UNSAFE or OK??????????
dont know wheater this means alot but the high speed needle setting was about half a turn in from base setting and the low end needle as base settings .
i am using 25% tornado fuel and the engine has had about 1 gallon through it.
why didnt i put a throttle return spring on?????????????
thankyou
boo,hoo boo, hoo
thankyou
boo,hoo boo, hoo
UT
RE: plz plz help me plz
If it starts and runs with power it's fine....yeah add a return spring and check your failsafe out...even though a failsafe's useless if a servo fails...
ORIGINAL: badz
ps it had nothing to do with the failsf, the throttle ball joint fell off so the carb intake was free to open, hence why full throttle came on.
dam i burnt my slipper clutch OUT
FL
ORIGINAL: crashing-is-fun
hi everyone
thankyou
boo,hoo boo, hoo
hi everyone
thankyou
boo,hoo boo, hoo
FL
i wouldnt do that if the truck was dirty being how dirt would get sucked right down into the crankcase
next time eaither plug the exhaust or rip the fuel lines off
ORIGINAL: losi xxx-ntkid
ha ha ha[8D] i know how 2 turn it off but it just wouldnt die.
I WANTED TO KNOW IF MY ENGINE IS STILL OK TO RUN OR IS IT UNSAFE?.............................. ARGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG
FL
well hopefully you didnt strech or bend the connecting rod
turn it over by hand with some after run oil in it and make sure it spins some what freely (take the glow plug out)
just try to start it
cheers just the info i wanted.
