xxx-nt wheel stripage
FL
i keep having this problem with my xxx-nt the wheels keep striping from the axle pin
what wheels should i get next?
i had hpi's but the hub striped out
this is about my 4th rim this has happend to not including the hpi's
and it doesnt do it to one side eaither it happend to both
sorry about the crapy pic
could it be that i am getting to much traction []
i am running in sand-dirt and a little on my buddys clay track
those are pro line gators (i think)
CA
RE: xxx-nt wheel stripage
does it keep happening to the same tire?
hows your clutch setup and hows your slipper? pretty tight? i use the slipper to save my parts not for traction totaly
FL
ORIGINAL: losi xxx-ntkid
i am running a 16 tooth clutch bell so it is set up for acceleration
they are some what tight
