Brake Rod not returning to idle position
Car is a Rush EVO, Gone through 2 pads so far the brake rod doesnt go back to idle position and causes the pad to grind down. I mad a little video showing this, i have to return the brakes to idle position by hand:
http://webpages.charter.net/supamantsi/Brakes.avi
Should I just try to apply some kind of lubrication? Im kinda stumped on how to fix this, I figured the pressure from the brake pad would return the bar to idle position but it doesnt, it just eats up the pad.
Should I pick up a fiberglass brake disc?
MN
RE: Brake Rod not returning to idle position
A collar on the front side of the lever will bring it back when you hit the throttle.
It is also a good idea to use nylon washers between the collar and the brake lever to minimize metal to metal contact(radio interference)
