good tire for oval dirt track rush evo
done my 3rd race and got 4th in the A main, not to bad I suppose. Just haven troubles hooking the rear end up to the track, I gas it and it breaks the rear tires and does the snake walk down the straight. Im running pro line bow tie tires, is there any kind out there I can get to hook up better or a set up?
What say you? Thanks
RE: good tire for oval dirt track rush evo
Sounds like the oval track you race at is loose dirt. On our local tracks we run the Striker 2 road tire or the Duratrax road tire. Seems like your track is alot looser than are hard packed clay track.
You could try some stiffer foam inserts in the tire like Trinity Bomb 1 or Proline Ultra firm foam to keep the tire stiffer and will get you a little more traction. I would try running the slipper clutch a tad looser and roll on the throttle a little smoother and see if that helps to. I like Proline Holeshots for loose tracks and Bowties as well. Might want to try some Losi Reptilesin a soft compound as well.
