"Show me your RC10 GT!!!!"
My Feedback: (16)
CA
RE: "Show me your RC10 GT!!!!"
Here is my RC10GT...all stock minus Futaba radio gear, and RPM Torkerz with Dirt Hawgs and Dirt Works...sold it though. [X(][X(][X(] Then, I bought a Savage 25.
MD
BadMammaJammas - Those rear wheels/tires i have. Same combination too LOL!!! they are discontinued saddly. They are a really hard rubber, i mean REALLY HARD! YOU CANT BEND THEM! They are great! i still have mine, word of advice, use them only for dirt.
#37
Here's my GT
Rpm front a-arms
Rpm rear a-arms
Rpm bulkheads
Rpm spindle assemble
Rpm rear arm mount
Airtronics Radio
Airtronics Reciever
Trinity Hump pack
Aftermarket shocks - forgot brand
Proline Striker 2 tires
3 piece rims
Rpm front a-arms
Rpm rear a-arms
Rpm bulkheads
Rpm rear arm mount
Airtronics Radio
Airtronics Reciever
Trinity Hump pack
3 piece rims
#40
i still have a tub chassis laying around from when i had my RC10GT..........i actually liked the tub chassis better BUT i hated cleaning it after it got dirty
#43
it obvisouly wasn't new...mabye a site like ebay, or even here on the classifieds...[:@]...evader driver are you like 2 years old...why the hell did you ask a question as dumb as that?
#46
Hey guys,
I know its not really the post to ask but is it possible to build a rc10gt from groung up?
where should I look to bu all the parts? I want a race winning rc10gt.
cheers,
Phil
cheers,
Phil
#48
check your pm's bud just buy a rtr plus and upgrade it as you need too. trust me you will build it from the ground up sooner or later lol
#49
ORIGINAL: Oliver_Klozov
Just doing maintenance or replacing parts, you'll end up taking the whole thing apart, if not all at once, section by section!
Oliver, how'd you setup the lights on your GT body?
#50
http://www.rcuniverse.com/forum/m_54...tm.htm#5516859
for anyone interested in putting L.E.D.'s in there car
You need
- Wire
- Transistors
- 9 volt battery
- 2 way switch
- Glue gun
- Drill
- Soldering gun
- Super Bright L.E.D.'s
- Duct tape
I used the glue gun to hold the led's in place when i drilled the holes also used it to hold the transistors in place on the body. This was my first attempt and the problem i was having with overheating of the battery was due to the three way switch i was using i wanted to do front and back seperate and at the same time sometimes. Next time i will use a soldering gun to attach the transistors to the wires instead of twisting them around the wire and encasing them in glue this worked but i found over time the connection on two lights became loose under the glue. So next time its solder. I'm waiting till i find my next body and i will do it up with lights that was my stock body and just wanted to test it. I use an on-road rx-8 body thats modified to fit here's a pic
You need
- Wire
- Transistors
- 9 volt battery
- 2 way switch
- Glue gun
- Drill
- Soldering gun
- Duct tape
