RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
servo saver
Old 10-27-2005 | 01:59 AM
Default servo saver
the saver on my JR NES591 steering servo is stuffed i think. after some jumps or large bumps the steering is suddenly turned alot to one side i trim it out and then later it happens again. the servo does look a little askew. does nayone know if this is the problem, and what servo saver do i need. i have a nitro sport with direct steering. thanks
Old 10-27-2005 | 05:26 AM
Default RE: servo saver
yeh it might be the servo saver but its probably the servo gears.
Dann
Old 10-27-2005 | 06:30 AM
gerwen's Avatar
Check to see if all the physical steering links are still intact. Is the servo still mounted solidly? If they are, then pull off the servo horn and observe how the servo moves. Does it move full left to right, and come back to center properly?
You need to use some troubleshooting skills to narrow down where the problem lies.
Old 10-28-2005 | 05:33 AM
yeah i did all those things gerwen. the teeth on the saver and the servo itself semed ok. maybe not razor sharp, but still there. i ended up buyinga new servo and saver. bluebird 620mg. seems good so far. huge torque 10.5 kgs/144oz
