RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
jato shiftin
Old 10-30-2005 | 06:58 PM
Default jato shiftin
i am in no way new to rc, but i am to st's, my jato won't shift to save my life, wat is the problem, sorry but im used to mt's that will shift not touching the tuning
Old 10-30-2005 | 07:03 PM
Default RE: jato shiftin
Read the manual. Toward the back of the car where teh transmission is located, the is a piece of rubber that you lift up and you will see a hole, then you have to line that hole with another hole inside there by turning the spur gear. The once you have the two holes aligned, take one of teh allen wrenches and turn it clockwise to make it shift later (I think, check in the manual), and counterclockwise to shift earlier. Check in your manual for a better understanding.
Old 10-30-2005 | 08:28 PM
done that and nothin, is there a sweet spot in the tuning
Old 10-30-2005 | 08:55 PM
Is this a brand new jato, or did you buy it used. That's a brand teaser. I don't know what else you could do to make it shift. I have a jato adjusting the transmission works fine. If its brand new, it must be something defective about the car.
Old 10-31-2005 | 08:14 PM
i bought it new the day they came out, i broke it in and have been drivin it on and off since then, because i have a savage which consomes must of my time, also how long after u press the accelerator should it take to shift.
Old 10-31-2005 | 09:25 PM
about 3 seconds.
