RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Jato vs stadium maxx
Old 11-08-2005 | 04:51 PM
Default Jato vs stadium maxx
Which truck would you prefer the Jato or the stadium max i will be using it to just mess arouns some mild jumping and a little of parking lot fun. I know that jato is way faster but is it sturdy enough to still have fun with jumping and messing around in parking lots.
Old 11-08-2005 | 07:34 PM
Default RE: Jato vs stadium maxx
Jato is very tough, very fast, and very fun. Many upgrades are beggining to come out to. Get the jato, you will def not be disapointed. I take mine up jumps all the time and do not break much at all. Havent even broken an arm yet (only rear shock tower from landing upside down 7 ft in the air). Wheelies galore to.
Old 11-08-2005 | 08:11 PM
f150dan's Avatar
My Feedback: (18)
The stadium maxx could be used on alot more terrain, and it would handle the bigger jumps better. But the Jato would definately be faster.
Old 11-08-2005 | 09:09 PM
I was wondering what the major differences were between these two myself, I mean both are STs, 2sp trans,use the TRX 2.5, I guess the gearing on the Smaxx is different? does the Smaxx have higher ground clearance?
Old 11-08-2005 | 09:15 PM
NitroRunner's Avatar
Ya the stadium maxx looks like the t maxx minus 4 wheel drive. Id say get the jato, its a sweet truck
Old 11-08-2005 | 10:00 PM
the stadium maxx IS a t maxx with out 4wd and reverse, so its not a stadium truck like they claim, its a 2WD monster, but yeh get a jato, speed is your friend
Dann
Old 11-08-2005 | 10:41 PM
CarTireDragbike's Avatar
What make the S-Maxx not a Stadium Truck. Sportwork's has a ST that is 4 wd.
Old 11-08-2005 | 10:43 PM
if you are looking for ground clearance then get the S-Maxx if speed and a low stance get the Jato.
Old 11-08-2005 | 10:50 PM
ground clearance and overall design, cog, etc. and your right a ST can be 4wd just not a high ground clearance monster truck.
Dann
Old 11-08-2005 | 10:52 PM
but... if a s maxx is a ST and a ST can be 4WD is a T maxx a ST, no, and if i turn up to my local track with a s maxx they are not gonna let it into the ST class.
Dann
Old 11-08-2005 | 10:57 PM
Since there is no track local I will just go with what you say. I don't agree that the S-Maxx with a low stance and good set of tires would not make it a True ST. JMO
