jato heat problem
CA
hey i noticed (before i crashed) my jato it was steaming is that normal after a normal cruise(not fast) run of 1 tank? if it is not normal wht do i need to do to make it stop like wht needle do i need to lean out? i can get you guys how far i am out on the hsn and lsn if you need it to give ma an answer...
jeff
jeff
just lean it out dood...i had the same thing happen yesterday..i done a couple of hi speed runs then i got a huge drop in performance and steam or smoke was rising from the engine head...i thought i cooked it for sure..i left it for 5 mins to cool as it was sooooo hot, then leaned it out a little and started it back up...then BAM, it took off like a rocket
i love my jato
anyone know where i can get a Blue jato shell in the U.K, and how much? also what tuned pipe should i get? lol
i love my jato
NC
yeah i think nitroeddie is right...my jato ran rly hot and i just richened the HSN a little and it was fine...when u run rich it gives the engine a little more lubrication wich will in turn shed some heat...
ORIGINAL: quango2k
i love my jato
i love my jato
eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeebay
