rush evo trouble
I must be the dumbest person on the planet. i have taken my rush evo apart, completely apart and i cant put it back together again, the exploded views in the ack of the manuel are too complicated, are there any re-building instructions around? i have tried searching but found nothing.
MO
LOL
Did you get the screw all mixed together? If you look at pics that should help you put the parts back together. Other than that, you will have to use exploded views. Just follow the lines on the views to show where the parts go. You'll get the hang of it.
Ethan
Did you get the screw all mixed together? If you look at pics that should help you put the parts back together. Other than that, you will have to use exploded views. Just follow the lines on the views to show where the parts go. You'll get the hang of it.Ethan
now try doing that with a monster truck!
but seriously this is the only way to ever learn how to work on your car, and after you figure out what goes where, it becomes fairly simple, and you will be able to dissassemble different areas very fast.
ON, CANADA
How many of you out there have had their truck apart like that? (and how many times?)
i know i've had my Rush apart 4-5 times so far, and i'v had it since the middle of last summer
ive never had my truck completely apart, i just work on the areas that need servicing. in fact, the only time that one of my cars is COMPLETELY apart is when i build a kit.
ON, CANADA
I meant mostly apart, for instance, almost bare chassis, maybe with a few parts left on, like the engine plate, diff mounts, little things like that that don't need to be taken off for cleaning or something. on the rush the upper deck/front bulkhead/suspension/tank/radio box etc. comes off in pretty much one piece, and then there's just the drivetrain and rear suspension left.
i only took it to bits because i bought it 2nd hand and it was broken, needed alot of work, so ive bought all the new parts i need and some hop ups, now just sticking it back together again. i want some masher 2000 tyres, will i need to strengthen anything (gearing) or will it just work?
http://www.hpieurope.com/kit-updates...&id=2004030301
there are some photos here
try looking at the photos and seeing where the major stuff goes
ORIGINAL: simple101
I have done it! lol here is a pic [link=http://www.canuckoffroad.com/images/gallery/978_thumb_broken%20car%20032.jpg]http://www.canuckoffroad.com/images/gallery/978_thumb_broken%20car%20032.jpg[/link]
you should take some pictures of it when youre done.
