RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Can I fix this?
Old 04-04-2006 | 03:03 PM
Default Can I fix this?
I was trying to get my battery plug out of my reciver and low adn be hold it all broke to peices..Is it possible to cut the wires of my old servo adn then cut off my battery wire and then solder it together so I got a plug? I will buy a new s/w when I can get to the hobby shop. Just wanna drive my truck...lol. Another question my tires came unglued today from them balloning. Is ther any way to get them to stay on?
Old 04-04-2006 | 05:24 PM
Default RE: Can I fix this?
Holly Crap you've done it now. You got buy everything new! Just kidding. You just clip off the ends from the old rig and solder it on. Get some shrink tubing to cover the soldered area. DONT forget to put the shrink tubing on the wire before you solder. : )
Old 04-04-2006 | 05:27 PM
The tires shouldnt come unglued. You didnt do a good enough job gluing. Clean up the wheels and tires and make sure you're using ca made for rc and do it again. Make sure you get glue all along the bead. Then put a rubber band around the tire. One on each side to hold pressure on it and let it sit. You can use a hair dryer to warm up the area a bit to make it dry faster. They should not come unglued.
Old 04-04-2006 | 05:51 PM
Also you can use tape on the inside of the tire to help stop the tires from balloning
Old 04-04-2006 | 06:53 PM
That was the first set of tire I glued on so it was a crap job...lol. I am using great planes thin CA. I will fix that servo after school tomorrow.
Old 04-04-2006 | 08:30 PM
laserman2's Avatar
remember line up the colors ie red to red black to black when you do the work or you will short it out
Old 04-05-2006 | 05:11 AM
Well my S/W harness only has black line but i knew about lining up the colors.
Old 04-05-2006 | 05:44 PM
i was reading you dont want to have the glue on the area were the Chrome is becaues it wont stick to it
Old 04-05-2006 | 06:42 PM
I got my tires gleud on good now, but I am kinda ticked oof because I just bought brand new RPM rims and on the 7th tank there is a peic missing from the sidewall. RPM better replace these rims or I wont buy from them ever again. Also I am experincing problems with my steerign servo. IT was doing it a few days ago so I put a set of freas batteries in and it helped a little. What is happeneing is that my servo is turning really quick to one side then when it turns to the other side it is right slow adn wont go all the way. Do you think it is time for a new servo? I got my wires fixxed too.
Old 04-05-2006 | 08:58 PM
MONSTARUSTA's Avatar
take the servo out and see it it still does it. If it doesn't check the steering for binding.
Old 04-05-2006 | 09:35 PM
You dont have to take the servo out. Just take the ball cup off the bell crank. Now turn the wheels by hand. If its binding it's not the servo. You have to maintain the bell cranks are this will happen eventually. A mip zero maintenance steering setup w/ball bearings is about 20 bucks. Well worth it.
Old 04-05-2006 | 09:57 PM
unclezesta's Avatar
do you think that would fit on a nitro rustler?
Old 04-05-2006 | 10:21 PM
Now that I think about it I'm not sure what truck this guy has. I was assuming he had a GT. I dont think he said what truck he has.
Old 04-06-2006 | 06:25 AM
I ahve a rustler....lol. I will check that steering thanks.
Old 04-06-2006 | 12:47 PM
ORIGINAL: Blitzz
It won't happen. All it takes is a little tap or tumble to make a the chrome plating chip off. A little tumble can also cause the wheels to occasionally crack. Accidental damage is not covered under ANY manufacturer's warranty.
Old 04-21-2006 | 10:45 AM
i got my first new set of rims from proline and i did a crapy job of glueing them. look wat happend:
