RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
axle is stuck.......help!!!!
Old 05-11-2006 | 05:46 PM
Default axle is stuck.......help!!!!
ok, well i am putting on the original tires on my jato, so i got one done and ready. but now this other one just wont come out. well, the pin that holds the axle in place wont come out, its stuck so everything else wont come loose either. do you guys have any idea what i can do to get it out, i sprayed wd-40 on it but that didnt help at all. anyone?
Old 05-11-2006 | 06:35 PM
Skullbasher's Avatar
Default RE: axle is stuck.......help!!!!
If it's the pin I'm thinking of, some vice grips should get it out easy. Make sure the pin isn't pulled right up against the bearing either, it sometimes makes it tough to remove.
Old 05-11-2006 | 07:07 PM
it was able to get out with vise grips because its inside the linkage, but i got it out. all i did was drill a hole in my plastic vise and grind down a nail. then i put the nail in the linkage and in the vise and closed it, came out great.
