evader st ?
PA
evader st ?
i have two questions about my evader and ive asked on the official thread but no one seems to awnser. what make of wheels will fit the st? i.e. rc 10 or losi. i want good wheels but i dont know which ones will fit. and also my gear diff melted the center out so i replaced it, but when i put the gear diff balls back in they seemed real loose in the gear diff holes is this correct or not. thanks if you can help.
CA
RE: evader st ?
not sure about the diff.. i just melted mine as well and haven't gotten around to rebuilding it.
As far as the wheels are concerned, you need to use losi or xxt rims.. hear are three links
http://www2.towerhobbies.com/cgi-bin...xt&FVPROFIL=++
http://www2.towerhobbies.com/cgi-bin...ms&FVPROFIL=++
LA
RE: evader st ?
You might have to tighten your diff more. If you have it installed, try turning one wheel. If the other one turns the other way, or the tranny dosent move, your diff is too loose. These diffs have to be real tight most of the time. For the rims, pin type rims, or losi rims will fit.
