3x-nt break suck
WI
3x-nt break suck
my friend has an 3x-nt and he just put a brand new os .15 in it but he cant seem to get it to idle and the rotery carb not like a slider but the outher one wont let servo pull back hard enough to be able to get some good breaking
any clue on how to fix this
he called me up to fix it and i cant some you guys are gona have to help or im gona have to spend my money to let my lhs have a crack at it
and i LOVE my money gentle men
FL
RE: 3x-nt break suck
Well you, or your friend ( ) just needs to learn how to adjust the brake arm thats all. Theres a little coller with a grub screw in it all the way in the back of the rod. adjust that and you , or your friend ( ) , will have a funtional brake
NY
My brother and I both have XXX-NTs, and we have found that the brakes on them tend to suck period. The best trick we've found is to glue some 400 grit sandpaper to both brake pads, it wares down your break pad faster, but it's one heck of a performace boost!
What confuses me is that I have also realized that the brakes suck too but I know that GPM makes a titanium brake that looks extremely trick but What pads would you use with these? I assume you wouldn't use stock pads right?
