RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Throttle Problem - HPI Nitro MT
Old 06-02-2006 | 05:20 PM
A1Viper's Avatar
Default Throttle Problem - HPI Nitro MT
Hey guys,
I just bought a used Nitro MT and am having a problem with the throttle. The Airtronics Blazer Sport radio is a fixed 70/30. Well when I pull full throttle, the carb opening goes past full open, so I'm losing power. I get to full open at about 70% throttle. I have messed with every adjustment on the darn thing and cannot figure it out, so any help is greatly appreciated.
Andrew
Old 06-02-2006 | 06:53 PM
Default RE: Throttle Problem - HPI Nitro MT
Did you try the throttle linkages???
Old 06-02-2006 | 08:53 PM
laserman2's Avatar
Look closely at the unit as i i have looked at pics of it on the net and it seems there might be some sort of adjust ment on ther for 50/50 70/30, but if there is none then do some adjustments on the linkages with your rx and tx on but not your engine and you should be able to set up the throttle just remove your air filter so you can see your movement in your carb and remember to put the filter after you have adjustments finished
Old 06-03-2006 | 01:42 AM
A1Viper's Avatar
I've tried everything. There is no adjustment for 50/50, and I've messed with the linkages.
