RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
I need help quick :(
Old 06-14-2006 | 08:15 PM
×SlappY×'s Avatar
Default I need help quick :(
ok, on my fuel tank, little plastic cylinder thing that you connect the fuel line from the carb to the tank snapped.. i tried super glueing it back but the nitro seems to turn it into goo... what else can i use?
Old 06-14-2006 | 08:25 PM
and_des's Avatar
Default RE: I need help quick :(
i know there some threaded nipple you can buy but don't know if they will fit if not you are in for a new fuel tank.
×SlappY×'s Avatar
lame. how much are fuel tanks, and does any fuel tank fit? i have a xtm-xcellerator.
Old 06-14-2006 | 08:33 PM
laserman2's Avatar
there are pressure nipples that go on to the exhaust that might work but it ould be the best to replace the tank if you can
Old 06-14-2006 | 08:38 PM
×SlappY×'s Avatar
alright. ill take a trip to my hobby shop and see what i can do. i dont wanna have to order an xtm tank and wait like 3 weeks. can i put like any 75 cc tank on my truck? or does it really have to be the xtm tank?
Old 06-14-2006 | 09:24 PM
and_des's Avatar
Any tank will do the trick just have to make sure it fits, i would bring my old tank with me and try to match it.
Old 06-14-2006 | 11:29 PM
×SlappY×'s Avatar
what ill try to do is enlarge the hole in the tank where the little tip thing snapped off, until its about the width of the cylnder, (the tube thingy) and then ill try and like jam it inthere, maybe silicone around it so no nitro can come out and sutff and keep it air tight. if that doesnt work then ill just buy a new tank lol.
Old 06-15-2006 | 09:23 AM
×SlappY×'s Avatar
yeah so i was tinkering on my tank, and i lost the little tab that snapped. so i was like bummed. but then i saw my old antenna tube lying right there and gave me an idea. i stuck it in the fuel line, and it was the exact width of the thing i lost. so i drilled the tank hole bigger so i can jam the antenna tube into it. its pretty snug, and it doesnt come out when i pull on the fuel line. ill silicone it to ensure it stays there [8D]
