Evader ST Exploded View - Where?
AR
I'm having some difficulty with my brake setup on my Nitro Evader ST. I was wondering if anyone knew of a website that had a better quality assembly diagram than what is on Duratrax's website. I have one on order but I wanna fix my truck tonight. You know what I mean?
WA
One spacer for each screw, the flanged on the bottom one facing the diff box. Put the screws through the two plates w/ the disk in between and push the screws into the holes and tighten each screw 2 turns each. So 2 turns on top, then 2 on bottom then 2 on top... Tighten all the way, then loosen to desired braking at idle.
