RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
starter spring
Old 09-01-2006 | 11:20 PM
So Cal's Avatar
Default starter spring
i have a nitro x-c with the stock .18 in it and i bought a new pull start (because i broke the origonal one) an when i went to start it it would slip and barley catch and turn over the motor.
wel any way i took it off to see wat was rong and the spring popped out. I tried for 20 min and cudnt get it wound back up....and my dad also tried and was unsucessful. i dont want to buy another starter and i dont know how i would get another spring in it if i bought another.
any suggestions? any suggestions appriciated
Old 09-02-2006 | 12:50 AM
Default RE: starter spring
It's extremely hard to get it back in and properly working when the spring had unraveled. But I have done it. it takes a lot of time patience and many times of failure to get it right. I usually wind it up out side of the case. Just put on eof your fingers on the inside and just start winding it back up. It takes time and do not wind it up to much as your finger will get stuck and you will not be able to get it back out until you unwind it again. Then once you wind it up then it's all about skill and luck. There are a lot of things that you have to pay attention to to get it to go in that little slite that it need's to slide in.
Good luck and I hope this helped.
Old 09-03-2006 | 01:12 PM
So Cal's Avatar
thanx for the adviseand i will go and try tonnight..
