Rustler bodies
The Rustler body will NOT fit the Nitro Sport. The front pins are in the correct place and alignment, however the rear pin is about 35mm to the rear and due to the position of the shock towers the Rustler body shock towers will NOT fit on the Nitro Sport. the position and relief in the plastic body does NOT allow a Rustler body to fit onto the pin of a Nitro Sport.
I have tried. Doesn't work even if you drill a new hole! the towers hit the body and the pin will not get up through the body unless you make MAJOR modifications to the body by cutting out reliefs for the towers to stick out of the body.
