RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
-=OFFICIAL HPI FIRESTORM THREAD=-
Old 09-12-2008, 07:47 PM
  #2901
IronHorse10
Default RE: -=OFFICIAL HPI FIRESTORM THREAD=-
I just got some new stuff for my FS. Axial Rocksters, Proline Gladiators, new spur gear (stripped last one), and and Integy fuel filter/primer.
Old 09-12-2008, 08:31 PM
  #2902
3d-flyer-93
What pull start will fit the g3.o?
Old 09-12-2008, 08:36 PM
  #2903
NitroNate
NitroNate's Avatar
Why do you want to change it?The Stock one is one of the best...
Thank you for going through that with me. I was actually talking about these clutch shoes. http://www3.towerhobbies.com/cgi-bin...?&I=LXVK12&P=7
I think I figured out how to put it on. The HPI rush has the same shoes and I just downloaded the manual. It goes right through the instructions. Now I see why i need to take my flywheel off....otherwise it is really hard to get those springs in there right.
Wait a minute.Why take off the flywheel?I slipped them right on....
Old 09-12-2008, 08:38 PM
  #2904
NitroNate
NitroNate's Avatar
Ironhorse,Nice ride!How do you like them Rocksters?Pretty awsome aren't they?
Old 09-12-2008, 09:37 PM
  #2905
IronHorse10
ORIGINAL: NitroNate
Yeah, I just got back from running it. The Rocksters are great, the tires are great. Integy fuel filter/primer... not so great. It leaked the first time I used it. I guess I'll have to try and fix that.
Old 09-12-2008, 11:05 PM
  #2906
NitroAddict83
Here is an update of my firestorm, I painted the shock tower, springs. etc. and the air cleaner. And some pics of the the clips I made
from zip ties, fuel line and toilet chain. I am not losing them anymore which helps. I also beat a savage xl on a straight run today and also jumped about 6 feet in the air off of a cement pad lip, too bad I went tumbeling and broke my fiber brake disk right off, i can't find it....good thing I have an extra one. thats amazing thats the only thing that happened. sweet.................! have fun out there!!!
ID:	1032135   Click image for larger version
ID:	1032136   Click image for larger version
ID:	1032137   Click image for larger version
Old 09-13-2008, 08:08 AM
  #2907
3d-flyer-93
what pullstart will fit the G3.o?
because the spring in mine broke
Old 09-13-2008, 10:12 AM
  #2908
fasty
are the Rocksters the glueless tires?
Old 09-13-2008, 12:51 PM
  #2909
IronHorse10
Yep.
Old 09-13-2008, 05:10 PM
  #2910
bushhiker
bushhiker's Avatar
Does any one know How to I make Proline 2.2 dish wheels fit my firestorm? i accidentally mounted my new sand paws to the wheels without checking if the wheels fit. It looks like the wrong hub clamp for the wheels.
Old 09-13-2008, 05:26 PM
  #2911
new22nitro
hey flyer you can go on youtube and this guy shows you how to respool a pullstart its not that hard just takes sometime and hurt ur hands let me know wat you think they have one on towerhobbies i think is like 15-20 bucks
Old 09-13-2008, 05:59 PM
  #2912
killsaurus
what kind of diff grease/oil do you guys use
Old 09-13-2008, 07:07 PM
  #2913
garzzar
garzzar's Avatar
haven't posted in awhile but im still tweakin on my FS
i just picked up a new breather for it, well actually its to cool the oil on the head for cars but with a small mod to it it works better than the stock one
step 1 open package
step2 shoved the blue filter from the stock one down in there, otherwise it would be just a metal filter
step 3 installed it on the FS
so there you have it, the body fits great, increased air flow, and it looks totally awesome
ID:	1032705   Click image for larger version
ID:	1032706   Click image for larger version
Old 09-13-2008, 08:47 PM
  #2914
Split7
what do u have to do to make the firestorm race good at club lvl besides a diffrent engine?
Old 09-14-2008, 10:30 AM
  #2915
NitroNate
NitroNate's Avatar
New tires and aluminum parts on the front for more steer traction.Thats about all it takes.
Old 09-14-2008, 10:56 AM
  #2916
NitroAddict83
I think you might want to get a high torque steering servo.....also
Old 09-14-2008, 11:25 AM
  #2917
NitroAddict83
Hey NitroNate,
what kind of tires would someone use on the firestorm for racing? just curious.... Hey and are you still running on those MOABS? I run them for more ground clearence, pretty much bashing... and then I also use my stock front tires with some Proline Gladiators in the back,,,what a good tire.....
thanks
Old 09-14-2008, 11:52 AM
  #2918
ImpalaPolicePack
ImpalaPolicePack's Avatar
hi
i went bashing in the mud yesterday and today i noticed a resistance in the rear wheel when i push the car... i put wd-40 on the wheel bearing and checked the clutch spring but its ok
anyone can help me ?
(sorry for my english im french)
Old 09-14-2008, 01:53 PM
  #2919
new22nitro
y do you guys put zip tyes on the cooling head wats that for?
Old 09-14-2008, 03:29 PM
  #2920
08firestorm12
i race at a dirt track once a week and I have the stock tires on the front and I bought a pair of Proline Dirt Paws for the back...they seem to work great!!
Old 09-14-2008, 06:21 PM
  #2921
garzzar
garzzar's Avatar
the zip ties are there incase of a roll over to protect the head from scratches and such
Old 09-14-2008, 09:19 PM
  #2922
bushhiker
bushhiker's Avatar
Does any one know how to make proline 2.2 dish wheels fit my firestorm. Also what tires and or adjustments should i make to do wheelies?
Old 09-14-2008, 09:50 PM
  #2923
BlindObject
BlindObject's Avatar
ORIGINAL: impalapolicepack
hi
Is your brakes even slightly pressing? check clutch and gearbox.
Old 09-14-2008, 10:00 PM
  #2924
ambassador27
Blind Object,
Check your exhaust gasket, mine was doing the exact same thing.. I found the header loose from the factory then I noticed some/alot of spent nitro right underneath where the header connects to the motor, pulled it and sure enough my gasket was split...
If this is the problem, try Nates fix and get some auto gasket or Tower Hobbies sells them in a 5 pack...
Old 09-15-2008, 01:10 AM
  #2925
ImpalaPolicePack
thanks! that was the brake, there was dried mud dehind the disk
