RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
-=OFFICIAL HPI FIRESTORM THREAD=-
Old 03-01-2009, 08:32 AM
  #3901
fasty
Default RE: -=OFFICIAL HPI FIRESTORM THREAD=-
nice pics that first 1 si really cool
Old 03-01-2009, 01:01 PM
  #3902
nitro-rob
nitro-rob's Avatar
ORIGINAL: embesh
Ok getting this firestorm ready to go. Couple things I notice. The a-arms on the firestorm have play. Can can you do anything to tighten that up? Maybe a bigger pin? I dont like that at all. Also that play at the tops of the shocks. I guess thats ok. Guess thats the way rtr trucks come. (Little Flimsy) Also, whats up with the red o rings in the rear dogbones. They are just squeezed in there? Mine fell out just sitting there. Havent even run it yet.
I have experienced none of these things with my firestorm. There is very little play with the a-arms, the o-rings havn't come out and the shocks are tight at the top mount. I don't think RTR is the problem, almost everything comes that way these days and usually the same parts are in the kit versus the assembled truck. Are you sure that what you are observing isn't normal and consistent with all trucks? How many trucks have you had before?
Old 03-01-2009, 01:04 PM
  #3903
nitro-rob
nitro-rob's Avatar
Junville - yeah, it sucks. We were teased with decent weather for a few days and now its -15C. Its funny how a few good days at the end of feb make people forget that March is usually the worst winter month. Until then, I clean, build and wait.....
Old 03-01-2009, 07:58 PM
  #3904
kawaboy101
So is the firestorm a good truck just to play in the back yard with mabye hit a few tracks?Im failry new to nitro.
Old 03-01-2009, 09:58 PM
  #3905
embesh
My only other stadium truck is a 10 year old Losi GTX. It is in mint conditition. Ill keep it that way cause there discontinued and no more parts. Anyhow, Right out of a sealed box, yes this firestorm (I have), has play in front and back arms. My Losi has 0 play. ( Graphite arms) And yes at the top shock bolts, I can twist the shocks back and forth. Play. Im sure its supposed to be like that. Just looking to see what others have done with there trucks. I would feel better if I could get the play out of the arms. Local shop said the composite upgrades take it out. Anyone know if thats true?
Old 03-01-2009, 10:32 PM
  #3906
JUBE
my wing adapt to my argentine fire did you like it???
http://img171.imageshack.us/img171/7341/27022009340.jpg
http://img55.imageshack.us/img55/4776/27022009341.jpg
Old 03-01-2009, 10:51 PM
  #3907
nitro-rob
nitro-rob's Avatar
The twist at the top of the shocks is because they are mounted on ball joints, it is supposed to be there. A little wiggle in the a arms is normal. The O-rings are set in place but should be held in by the dogbones.
Kawaboy - The FS is a great truck, especially if you are new to nitro. Its easy to tune and there is a good base of knowledge on it in this forum, I suggest reading the manual carefully from cover to cover and going through the forum - you will see the kinds of issues that come up repeated throughout the 150 pages. It was my first truck which was great to learn on and I keep it among my more 'senior' trucks still and its still my favorite.
Old 03-02-2009, 12:05 PM
  #3908
JonKBMW
So I bashed around with my Futaba 3305 servo, and now my steering is broken haha. The servo moves, but the wheels only move like 3 deg left to right. I peeked inside and it looks like the arm thing that the servo hooks up to is broken I think I saw a crack that opened up when I would turn the steering. I think this is the "servo saver" but I am not sure. So I ordered a new "servo saver" set... so, we'll see!
Old 03-02-2009, 07:17 PM
  #3909
eddyeddy
Would this engine perform better than the OS 18 CV?
http://www.amainhobbies.com/product_...ducts_id/32512
RB Concept C12 3 port
I think the only change would be the slide to rotary carb.
Old 03-03-2009, 09:31 AM
  #3910
fasty
good lord this weather is killing me.I want to run my storm.any one else got the jitters about this bad weather keeping you from running your storm?
lets all pray to the sun gods lol
Old 03-03-2009, 10:48 AM
  #3911
nitro rc
ya i feel the same way. Everything here in CT was melting and drying up and now we just got another foot of snow. I really want to run my rc's but can't.[:@]
Old 03-03-2009, 01:12 PM
  #3912
bushhiker
bushhiker's Avatar
Does anyone know if this 2-speed will fit the firestorm? (hopefully it will!!)
http://www3.towerhobbies.com/cgi-bin...?&I=LXBTB6&P=7
I really want a 2-speed for more top-end without sacrificing bottomend.
Old 03-03-2009, 06:55 PM
  #3913
nitro-rob
nitro-rob's Avatar
That transmission is for the RS4 and can be adapted easily to the MT2 but for the FS it would be a custom fit. Somewhere in this thread somebody put a two speed in and I think it was borrowed from the RS4. There isn't a lot of space for it...
Old 03-03-2009, 09:45 PM
  #3914
bushhiker
bushhiker's Avatar
So do you think it would be worth it trying to fit it on the storm?
Old 03-03-2009, 09:54 PM
  #3915
bushhiker
bushhiker's Avatar
Old 03-03-2009, 09:57 PM
  #3916
J_Voisel
Which tires would be best for mostly onroad but would still grip if I ran out in the grass, and not get torn up in no time at all? I've torn through two pairs of the Pro-Line Snake Eyes because that's the main thing the hobby shop carries. Thinking about just getting a set of street tires but then it would suck out in the grass.
Old 03-03-2009, 10:06 PM
  #3917
nitro-rob
nitro-rob's Avatar
That 2-speed wouldn't likely be worth it, its exposed and can be subject to debris etc.. and even HPI doesn't recommend it for the MT2. The best solution is likely a sealed 2-speed transmission to replace the entire transmission of the FS - you will have more room to work with than trying to add a 2-speed to go in tandem to the one speed that is already there.
I use roadrage II tires for the street but they are gargabe on grass and I normally use a different off road setup. Gladiators have a good reputation for wear being good on a wide range of surfaces.
Old 03-04-2009, 03:47 PM
  #3918
bushhiker
bushhiker's Avatar
Will the savage 2 speed be able to replace the entire transmition or is it too big?
Old 03-04-2009, 06:49 PM
  #3919
nitro-rob
nitro-rob's Avatar
Oh yes, way too big.
Old 03-05-2009, 08:25 PM
  #3920
ambassador27
J,
I run Yokohama Geolanders the same tires that come stock on the MT2, they work great in the grass and on road.. Just my 2..
Old 03-07-2009, 01:36 PM
  #3921
nitro-rob
nitro-rob's Avatar
So yesterday was warm enough to drive and I was home from work at 3 but I didn't have my glow ignitor or hump pack charged. Thinking ahead I picked up some fuel (25% sidewinder) to get ready for the weekend which was looking okay. This morning I quickly went to get groceries - it was just warm enough and dry outside. Then it started to pour when I got home.
Looks like a good day to get my tax return in....
Old 03-07-2009, 02:17 PM
  #3922
junville
i heared from somewhere in this forum that the geolander tires have some problem fitting in. I know it fits with the hex but i think someone mentioned that either the turnbuckles get in the way or some sort.. I am also thinking of putting these tires on my FS but just want to resolve this issue first. Any info would be greatly appreaciated.
Old 03-07-2009, 07:28 PM
  #3923
nitro-rob
nitro-rob's Avatar
I put my geolanders from my MT2 onto my FS no problem. I don't know why people said they had problems, they fit on a standard 2.2 14mm hex rim and aren't extra wide or anything to interfere with the steering.
Rain rain, go away.....
Old 03-08-2009, 09:09 AM
  #3924
ambassador27
No Problems at all, the Geolanders fit just fine and are a good all around tire..
Old 03-12-2009, 07:31 PM
  #3925
lowridz87
hey im lookin at a e firestorm. any advice? i havent seen anybody with hpi trucks in tulsa. it seems to be all losi and traxxas(im kind of new to rc). i have a revo 3.3 now and love it. want to try diff things tho. thanks
