RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Tires
Old 12-16-2006 | 01:05 PM
Default Tires
hey guys what proline tires would be good for backyard bashing? the surface i usually ride on is a little loose and lots of gravel. im looking at the bash tires not the racing ones. the car i run is an XTM X-Cellerator. all im looking for is the rear tires.
Old 12-16-2006 | 01:15 PM
Vigilante212's Avatar
Default RE: Tires
dirt hawgs work well and last a long time.
Old 12-16-2006 | 03:15 PM
NewfieNitro's Avatar
Default RE: Tires
well mashers or moabs on front and bac would be worth the investment because of all the extra ground clearance. Ground clerance = better bashing
Old 12-16-2006 | 09:02 PM
Default RE: Tires
buy 4 dirthawgs and have fun.
Old 12-17-2006 | 10:45 PM
Default RE: Tires
Dirt hawgs do last a very long time for general bashing.
Although, I found if your bashing say on a dried dirt area, some place you can take high speed turns, Lugnuts are the way to go! They just dig.
Old 12-17-2006 | 11:16 PM
Default RE: Tires
ORIGINAL: EvaderST123
ground clearance=better bashing=way more broken parts
Old 12-19-2006 | 02:48 PM
osuwins's Avatar
Default RE: Tires
dirt hawgs are my primary tire for my jato on a 2.2 rim,i also run moabs on a 2.2 rim for ground clearance in some parksi might try a 2.8 rim next time,switch it up try different setups its fun, here r some tires i started with and use
ID:	580168   Click image for larger version
ID:	580169   Click image for larger version
Old 12-19-2006 | 04:13 PM
MrN8's Avatar
Default RE: Tires
I've got to agree that Dirt Hawgs are the way to go. They last a long time and transfer well from dirt to grass. I like the Moabs, but they do tend to tear the grass up a bit, so I don't run them when I don't want to take responsibility.
Old 12-19-2006 | 05:01 PM
Default RE: Tires
I use proline gladiators...ill have to try those dirt hawgs
Old 12-19-2006 | 06:17 PM
Default RE: Tires
dirtnap my dirt hawgs are like 3 years old i run on road dirt and tennis court 4gals of gas on them best tire i have ever had i will not buy any other brand of tire[sm=spinnyeyes.gif][sm=spinnyeyes.gif][sm=spinnyeyes.gif][sm=spinnyeyes.gif]
