evader st flywheel
OH
What actually holds on the flywheel> i dont have the piece that goes on the crankshaft, the like grippy piece, im still searching for that, but does the flywheel atcually screw on? on does it on on then you put hte other piece on that screws on, the one that holds hte clutch bell... sorry i dont knwo names lol, but is it just sandwhiched together between the screwy thingy and hte grippy thingy? sorry im usually better at this but i took a break from this for a year, then rebuilt this thing a while ago, had a tank leak, got hte rc10gt tank, installed, new tires, then this happened lol.. actually this tank has never been run. any help?
NL, CANADA
u have a collet and a flywheel the collet slides onto the crankshaft and then u jam the flywheel onto it u can only order then as a set tho
http://www2.towerhobbies.com/cgi-bin...?&I=LXDSZ6&P=Z
NL, CANADA
and the engine nuts screws on the crank and holds the flywheel from moving and it also holds the cb http://www2.towerhobbies.com/cgi-bin...?&I=LXDSZ7&P=Z
OH
Yeah, really odd problem the black piece the one that holds the cb, wont fit with the bearing that were on it, there was one on it, and it wouldnt even come off
I am upset adn cant get to the LHS and will be without a car still untill at least 2 days after christmas
OH
This is getting upsetting... please someone solve my problem please? i am having some trouble i havent been up the the LHS since then and i would like to knwo what all i ahve to replace here.. Please let me know
dude, the end is snug, its just part of the machining process, u just have to tug real hard on the bearing and it will come of easy, it happened to me, so i just got a file and filed the end a little, cause there were metal barbs on the end.
