RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
starting problems with jato
Old 01-12-2007 | 12:47 PM
Default starting problems with jato
i have a jato for about a year but now when i try to start it , it starts popping and sounds like a misfire but it doesnt even start up, how can i fix this?
Old 01-12-2007 | 01:12 PM
annie_himself's Avatar
Default RE: starting problems with jato
It is wanting to start sounds like, but I'm not sure about the loud pops. And these engines can't backfire.
How many gallons are on the motor? Was the EZ-Start pack charged? Is the plug good? etc..
Old 01-12-2007 | 01:16 PM
my e start is charged and it says the plug is working fine the engine is a simple trx 2.5
Old 01-12-2007 | 01:26 PM
How many gallons on it? Or maybe pints or whatever in your case.
Old 01-12-2007 | 01:38 PM
how do you find out how many gallons it has
Old 01-12-2007 | 02:34 PM
fool he means how many gallons have used you burke[sm=lol.gif][sm=lol.gif][sm=lol.gif][sm=lol.gif][sm=lol.gif][sm=lol.gif]
Old 01-12-2007 | 03:27 PM
probably about 1 gallon
Old 01-12-2007 | 03:28 PM
shuttup kemp nugar[:@][:@][:@]
Old 01-12-2007 | 04:36 PM
osuwins's Avatar
easy guys, but that is funny.., so you have hade this car for a year and only 1 gallon through it,hmm do you know what a gallon is,not 2b funny, how old are you, is this your 1st rc
Old 01-12-2007 | 07:13 PM
1 gallon and over a year old? Drinking can kill you you know..
Old 01-13-2007 | 05:24 AM
i dont run itb very often only about oncew every two weeks
Old 01-13-2007 | 05:25 AM
ive had it for about 8 months actually
Old 01-13-2007 | 05:28 AM
tell me whats wrong and how to fix it anyway
Old 01-15-2007 | 11:20 PM
get a new glow plug,regardless what yuor wand says, make sure your eazy-start is charged, put the carb back to new settings(high speed-tighten in until resistance is felt, then back out 4 turns,idle-1 1/2 tunrs out, and the screw on the carb slider should be even with the shoulder.)do you use after run oil? since you dont run it often, maybe shuold add an extra drop in the glow plug hole and dont run the exces out. I usually have to go thru one charged stick in the starter,(when its cold, I dont run every day as well, and I use wd-40) then grab another, then it will start easy, maybe get another battery for you ez start. also, keep your truck and gas inside. if your gas gets cold, it will gell. and if its old gas, its just not the same as new.also, dont put unran gas back in your gas container. I dont know if this helps, I dont know what youve done already. good luck
