RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
mt2 help--engine head
Old 01-12-2007 | 07:00 PM
Townsley's Avatar
Default mt2 help--engine head
i am having trouble with my heatsink part. evrytime i go to use the roto starter or starter box it always blows at gas from the heatsink. ive tightend it really tight on there to. ive takin it off and put it back on alot, and tightend it as tight as it will get. but it still blows gas out the side of it.? anyone have any suggestions? thanks
Old 01-12-2007 | 07:16 PM
djheptic's Avatar
Default RE: mt2 help--engine head
what engine do you have the t-15? i have heard about people sealing it. are you sure you put it back together correctly? also are you sure its not coming out the glowplug hole and leaking out one of the heatsink fins.
Old 01-12-2007 | 10:46 PM
46u's Avatar
46u
Are you tightening it evenly? If you do not the head will not seal If that does not work make sure the gasket or some call it a shim is in good shape or replace it.
Old 01-13-2007 | 12:32 AM
Townsley's Avatar
yea it is pretty tight. i did it over and over, and it still leaks =[ i cant figure out why. i will try again. how would i seal it though?
