RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
View Poll Results: A poll
traxxas
14.42%
duratrax
3.85%
wildcat
6.73%
cool power
0
0%
hpi
2.88%
megatech
0
0%
o donnell
25.96%
trinity
13.46%
other
32.69%
Voters: 104. You may not vote on this poll
what fuel do you use
Old 02-21-2007 | 05:00 PM
Default what fuel do you use
what kind of fuel do you use
Old 02-21-2007 | 05:13 PM
itsnotskidding's Avatar
Default RE: what fuel do you use
byron fuel.. 11% oil content and a world winning fuel aswell as o;donalds i think it is??...
Old 02-21-2007 | 05:54 PM
i used to use odonnel but i switched to trinity
Old 02-21-2007 | 08:21 PM
tgwolfwood1981's Avatar
Trinty monster brew. 20% nitro and 18% lubricant.
Old 02-21-2007 | 08:40 PM
I run Sidewinder and Backyard basher. They are both 20% nitro but Sidewinder is a race blend with less oil and performs a bit better. They are both made by Morgan Fuels and perform awsome.
Jason
Old 02-21-2007 | 08:49 PM
I use Blue Thunder 20%, but I'm thinking about switching to Trinity Monster Brew 20%
Old 02-21-2007 | 09:11 PM
Byron
Old 02-21-2007 | 09:49 PM
im running Byron in my mt2 got 2 gallons for free and my car runs great on it.and sidewinder in my tmaxx
Old 02-21-2007 | 09:57 PM
Blue Thunder 20%.
Old 02-21-2007 | 10:48 PM
46u's Avatar
46u
Brand is not the only thing to consider!!!!!!!! I run and like O’Donnell Race blend but will not run there RTR blend. Oil content is the biggest thing to consider and I will not run anything over 11% content.
Old 02-22-2007 | 12:15 AM
i run hpi 20%
Old 02-22-2007 | 12:22 AM
y dont they sell fuel in 1 gallon. its expensive to buy 4 gallons
Old 02-22-2007 | 12:27 AM
O'Donnell 20% here.
Old 02-22-2007 | 02:57 AM
custom mixed, 25% angus, 10% nitroglide.
Old 02-22-2007 | 07:14 AM
20% O'Donell
Have tried Trinity and liked it but the LHS stopped carrying it. Fantom fuels are also good fuels but once again my LHS stopped carrying them.
Old 02-22-2007 | 10:33 AM
46u's Avatar
46u
ORIGINAL: omg no name
i run hpi 20%
I tried HPI fuel once and if you use a good fuel you will see a BIG difference!
Old 02-22-2007 | 12:26 PM
Werks 20% race blend
Old 02-22-2007 | 12:30 PM
its a fact the anything above 8% oil content is a waste and can cause lean running due to smoke and oil spitting from exhauste....[>:]
Old 02-22-2007 | 01:47 PM
lewis_lfc's Avatar
i run 16% o donnell in my mt2 would i see a big difference in i changed to 20%
Old 02-22-2007 | 02:56 PM
ORIGINAL: crash_alot
Although I agree that anything more then 8% oil content is a waste. But the more oil content in the oil does not cause your enigne to run lean. Running lean is due to not enough fuel to the air mixture, and not the oil escaping from the exhaust. Now some noobs can over lean an engine due to having high oil content (the fuel) does not offer as much power, so they tend to lean it out till they get the power they want. Now they have a lean running engine that still spits out as much smoke as a race blend fuel does. And running it lean causes premature wear and kills the engine. But the engine does not run lean due to the oil not coming out of the exhaust, it's due to not enough fuel for the amount of air that is being introduced to the engine.
Old 02-22-2007 | 04:18 PM
well thats what i was meaning!..lol..
Old 02-22-2007 | 04:40 PM
Rebeldude's Avatar
Sidewinder 20%
Old 02-22-2007 | 06:23 PM
Nathan9492's Avatar
Massive Mods HB444 25%
Old 02-22-2007 | 07:46 PM
so how is massives fuel then? are you a nitrobuggies.com guy ?
Old 02-23-2007 | 01:38 PM
46u's Avatar
46u
Most are say a brand but not a blend!!!!!! Sidewinder makes 3 blends I know of Basher VERY HIGH oil content Race which is about 12% and Pro around 10% like so many other fuel manufactures! So it is not all about brand but all so the blend!!!!!!!!!!!!!!!!!! Read and learn.
Why 8% to 12% Oil
Using high oil content fuels in fuel car engines won't provide improved engine life, as some would expect. Through extensive testing we've discovered the point of diminishing return as far as oil content to engine life is actually around 8% for most car engines. In other words any more oil than 8% in the fuel does noting to improve the life of a car engine. In fact the secondary effects of high oil content fuels can actually cause engine damage by encouraging over lean runs. Here's how.
Using high oil content fuel causes a car engine to be unresponsive during acceleration acting as if the engine were running rich. Typically when using high oil content fuel, in order to get crisp acceleration and response, an engine will need to be adjusted overly lean. In addition the high oil content prevents lean bog when an engine is over-leaned thus allowing the engine to run at this lean setting without the customary telltale lean bog warning letting you know the engine is overheating.
In summary, high oil content fuels don't give added protection. The point of diminishing return from a protection standpoint in a gas car application is about 8% oil depending on the oil type and engine. Anymore oil than this doesn't offer added protection and has potential secondary effects that reduce performance and can actually cause you to over lean your engine in an attempt to get crisp throttle response and acceleration.
