Vapor lock???
AZ
I have a GT2 and love it. Lately when I run it, it will on occasion stop delivering fuel to the engine. When I check it out there are bubbles in the fuel line. This usually happens after it is warmed up. Is this because I have a stock pipe that does not have a pressure nipple on it? Any advice would be great. I am getting tired of it dying after half a tank.
Thanks, Travis.
Thanks, Travis.
I thought you had to have a pressure line from the muffler to the tank. Mabey you could make a nipple on the muffler?
My rigs:Warhead EVO and Nitro Evader St
you have a hole inn your fuel line. and you better make sure that your "stock" pipe really doesn't have a pressure connection on it. if so does your tank not have one as well? And if it does...is it plugged or is it just open.
AZ
I think I figured it out. I was just out tuning it and realized that my idol screw was not in. That was allowing the rotory portion of my carb to move back and forth. I fixed that and now it has not happended since.
Thanks, Travis.
Thanks, Travis.
