GT2 wont run correctly
I have a GT2 i did the proper breaking in proces it ran very well for about 10 tanks after the breaking in, but now it wont run longer then a couple of min, it wont over heat, i just stops running is almos like it would run out of gas but it does not. Has anyone had this problem before? and how was it fix?
BC, CANADA
RE: GT2 wont run correctly
i have the gt,but i've heard that some tank filters in the gt2 come loose or off and will not pickup fuel when the level in the tank goes down. . dan.
You have a PM
You have a PM
i was thinking exactly the same, but not to sure, but now im gonna try a new tank and see if that fix the problem? what do you think about putting a fuel filter??
BC, CANADA
My buddies say the tank filter in the gt2 is awsome(when working right of course) and while adding another one is good, it can caughts more areas to have a possible air leak. Later. Dan [8D]
Sounds like your pretty close to getting it running right i wouldn't move your screws much the weather changes alot this time of year.
