Factory Settings
This kid told me to tune my truck on factory settings if it gets screwed up. He said this...
Factory
4 turns out on high speed
Flush on low speed
1 mm on idle
What does he mean by this? which ways do i turn and how is this... IM LOST
Factory
Flush on low speed
1 mm on idle
CT
ORIGINAL: devsynski
Factory
Flush on low speed
1 mm on idle
Factory
Flush on low speed
1 mm on idle
Step 2, the low speed nedle, it just needs to BE FLUSH WITH THE PART THAT IT IS IN
Step 3, idle, take off the air fillter, mess with the idle speed screw until the gap between the metal part in the carb and the carb is only 1 mm (this is looking into the carb by the place were the air fillter base was.) also the gap will be on the left.
I know it is a little confusing just reply with any qusetions
