Rustler Splug-- HELLPPP
my rustler if brand new and isnt starting. the ez start worked fine until today. I used the ez start and it just wouldnt start. the rubber on the ez start wire is melted. i turned the tuning back to factory settings. I dont know what to do it wont start. Glo plug is fine. Also this gunk was coming out of the exhaust , carb, and cooling head. i would totally drain this stuff and think it must run now but it still wouldnt start. then again this stuff would fill back up and i will empty it out and rusty wont start! how or what can i do guys to get it to start. plz dont say buy anything, tell me what do without purchasing stuff. thanks guys I need it to start by Sat, all my buddies are going driving together.
MN
did you say gunky stuff was coming out of your exhaust and such??? well that is just half burnt fumes and fuel left in the exhaust but i have never heard of it gettting in the engine?? hmm try unflooding it like it was flooded and see what happens. btw do that while pinching the fuel like with a clamp or somthing. that will clean it out and then try starting it with the fuel line still clamped shut and see if it fires...i hope that helps. i had to do taht once
Dude !!! With all the posts you've made on here and running such hot temps and the gooky crud and all you probly baked yer motor , thats why it's not starting.
