RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
need help starting my evader
Old 07-10-2007 | 05:44 PM
Default need help starting my evader
i just tried starting me evader since a few months...it starts when i have it half throttle...and it remains running, but as soon as i take my finger off the throttle, it dies. do i need to adjust the lsn or idle? if so, in or out? thanks a lot!
Old 07-10-2007 | 07:54 PM
Evader ---> MGT's Avatar
Default RE: need help starting my evader
Your idle is too low, and that is killing the engine. Screw the idle screw in until you can see the carb open with a hole about the size of a pencil tip with out touching the radio.
Old 07-11-2007 | 05:32 PM
my idle screw is all the way in and theres no opening in the carb. is it something with the lsn? how many turns out from closed should it be?
Old 07-11-2007 | 05:43 PM
REDisFASTER's Avatar
Your carb HAS to be open for air to get in... If its closed, air doesn't come in, and the engine stalls...
Don't touch your LSN, just adjust your idle so that when the carb peg is set "all closed", that its only about 0.8-1.0mm open.
Old 07-11-2007 | 06:03 PM
ok i got it. it was the throttle trim. but now when it starts it idles for a bit and dies when i brake or give it throttle. [:@]
Old 07-11-2007 | 06:07 PM
Snaut Rocket's Avatar
lean your low speed a 1/8 of a turn and see how it is.
Old 07-11-2007 | 06:37 PM
Make sure the throttle trim is all the way back. That will stop the truck from dying when applying brakes.
