Weird Glitch???xxxnt__HELP
MI
I have been in rc bout 2 1/2 yrs but never seen this.? When I am running and go to punch it, bout 3/4 throttle the str servo turns right?? yes it turns right.??? I have a fail safe on it and it works fine, and i even reset it a couple times. But the thing still does it at 3/4 throttle. just when u are really moveing it goes into a spin?? I even checked all the rods comeing off the thr servo to make sure they arent touching any thing at that point and nothing there either....Any thing or idea will help out.!!!!!U COULD BE HUGE!!!!!Thank you
WI
RE: Weird Glitch???xxxnt__HELP
ORIGINAL: rclynx
Could be the rear end adjustment but I don't have a clue what truck it is[&:]
Mine doesn't do that, but it will do a barrel roll in mid-air. I think there is something wrong with the diff causing one tire to spin more freely than the other, but I am also a noob and kind of afraid to take the diff apart.[&:]
CA
look at the thread subject. "RE: Weird Glitch???xxxnt__HELP"
MI
when i have it on the starter box and let it free spin and give it throttle it does it at bout 3/4 thrott?? I dont think it in the diff like i said i just rebuilt it and i have done in the past maybe 3 times. but like i said it does it on the box the front steer servo will just turn at that piont?? I dont get it?thats what made me rebuild it i thought something was messed up and it was but it was the monster diff rings ,but like i said i put new balls in the diff so i am totaly lost on this one .....Its like a glitch but its not a open glitch because of the fail safe it works fine
CA
If you reverse the servo what happens.....................its fun to try and drive like that also so do it in a wide open area[&o]
