RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
GT2 engine problem
Old 08-03-2007 | 12:12 PM
daytimeninja's Avatar
Default GT2 engine problem
Ok guys, I just got done running mt GT2 with the stock engine installed. After about 10 minutes of driving, I heard something that sounded almost like air escaping. Does anyone know what could be the problem.
Old 08-03-2007 | 12:52 PM
Default RE: GT2 engine problem
did the performance change at all?
Old 08-03-2007 | 01:26 PM
was your plug tight, and was the cooling head on tight?
Old 08-03-2007 | 04:27 PM
jatoracing33's Avatar
is the idle ok? if not check your carb. also, check the exhaust coupling and line headin from your pipe to gas tank. check the gas tank too
Old 08-03-2007 | 05:44 PM
im assuming you heard this after the motor was shut off, when i get done running after a while i can hear what sounds like air coming out of the pipe...i think its just back pressure from the pipe....that might be what you are hearing
Old 08-03-2007 | 05:59 PM
REDisFASTER's Avatar
Try sealing your engine and checking to see if it goes away.
Here's the how-to that I followed: http://www.savage-central.com/module...wtopic&t=54465
Old 08-03-2007 | 08:38 PM
Ok thanks guys.
