help with rusty
WA
ok this is confussing...tryed to start my rusty today and everytime i put the ez start on it with the glow plug igniter and try to start it it would not start then when i tryed to radio and pulled on it it would go then, it would lurch forward and pull the ez start out of the end and it would stop and shut off. What could be wrong with it??
Thanks for the help
nitroman111
Thanks for the help
nitroman111
Take your air filter off and check the carb setting while your trigger is in neutral. It sounds to me as if your carb is closed when your trigger is in the neutral position.
