Quick CB help
Quick CB help
ok whats the pinch on a traxxas clutch bell off a rustler?i know the spur is 32P so is the CB the same
or is it 1.0 metric???
Edit:
oh and will a 18/72 gearing on a N-sport(pro.15) be ok with masher 2000`s
Edit:
RE: Quick CB help
32 pitch is very close to 1.0 but if you have a 32 pitch the other will be 32 pitch or they won't work for long. I know the jato has a 1.0 metric pitch and wont work with 32 pitch very well. You should be able to find the gears you want if you look hard enough. Sometimes you can use gears for a different car and they work fine.
