rear exhaust question
Hi i have a mt2 18ss and was thinking about rear exhaust on its but the only way that i see other people doing is to bend the header but before i do that i would like to know the up sides to a rear exhaust
thank you
rcbasher260
thank you
rcbasher260
RE: rear exhaust question
its got a side port exhaust right?
if it does you MIGHT be able to use a MIP Rear Stinger Exhaust Kit for T-Maxx(your have to rig up a hanger,so it dont fall off and whatnot)
and the 360s are for better low-mid range RPM..and they look cool
Most headers you cant bend because they are aluminum. It will break. Some headers you can put on backwards and most rear exhaust will come with a header.
GA
One of the dual exhaust manufactures on their web site talk about having to use a different header and having to bend the header pipe. The man think I do not like about rear exhaust pipes is I do not see how it can have very good flow do to the 90 degree turn the exhaust gases have to make. I just think there are more efficient pipes. Yes they look good and keep oil off your truck.
