Putting back the flywheel and clutch
Ok so ive got my new engine and my carb will be here soon , i need to attach my flywheel & clutch etc onto the shaft.. but when i put it on very tight i can still see The clutch and i know i shouldnt ... does any1 have any tips for putting it back together >?
RE: Putting back the flywheel and clutch
post pictures b/c depending on what engine your using and flywheelnut you might need to dremel or you might be ok. i can see my clutch shoes between my flywheel. I don't think the clutch bell needs to sit tighting on the flywheel.
But if u look in this pic its sat tight .. although my new engine is a hot bodies label and does have a few minor things different could this be one ?
yah you gotta fix that take the clutch bell off and post a pic from the top and from the end of the shaft. Is it a threaded shaft? Or a snap ring groove? Put a ruler up to it or you might call it a scale. So we can see how many mm's you need to cut off the shaft or it might be the nut just get the bell off and post a pic.
