a lil help
i got a hpi rush evo and when my car is runing and i have the wheels off the ground and i give it gas only the back left wheel is spinning fast when i pull the throttle but the right wheel does not spin fast like the left wheel what could the problem be
That is completly normal. Its a limited slip diff and both tires will not spin at the same time. If you give it gas and hold 1 tire the other will spin and vise verse.
If you stripped one side of the diff it would not move at all. Like I said hold 1 tire and the other will spin switch to the other and the opposite will spin. Its normal. Just like a car. If both rear tires spun at the same time the steering would suck. You dont have a problem!
