jato 3.3 Rear A arms
RE: jato 3.3 Rear A arms
I think all you have to do is remove the diff cover (like 4 screws). Then there is one screw that holds it on by the tire it is kinda short (think its called a knuckle?). After you have that out take a small screw driver and push out the metal rod through the hold on the opp side of that you just unscrewed that short screw out of.
NJ
Preety much the entire battery box has to come off for you to be able to get access to remove the rear a-arms. Theres only two chassis screws you need to remove, and the diff cover as well. It was a tough install for me when i upgraded my rear a-arms.
The rear arms are simple. You have the two bottom chassis screws ( the very rear ones), 2 battery box screws and 2 diff screws. Once you remove the rear diff cover with the battery box attached to the cover. the a arms pretty much fall right out. Everything else is pretty much self explanitory.
ORIGINAL: jatoracing33
if rear a arms are hard to get out then 2+2 must be the hardest math problem out there
PA
ORIGINAL: nick2618
no need to be like that. If you have never taken the truck apart it might be a little hard to get a first.
wasnt for me
NJ
Good for you mad scientist, you want a cookie? Your little baby hands may be able to fit in the jatos tiny crevices, but not mine. It was a pain in the ass, espcially when you dont have a manual and are doing everything by eye. Now go crash your jato into a tree an stfu.
