firestorm won't wheelie :(
OH
How can i get my firestorm to wheelie with out having to buy new gears? for tighting the slippper clutch how much i tighten it? I've already tightened it about 2turns and don't see any difference.
RE: firestorm won't wheelie :(
ORIGINAL: d3d5
thighten the slipper until it doesnt slip... and tune your engine right. then go WOT at a high grip surface but when setting the slipper to thight you may risk damaging your drivetrain
OH
ORIGINAL: xhaliex
ORIGINAL: d3d5
ORIGINAL: d3d5
i'll try that but I don't care if i damage the drive train because i'm going to be getting an os .18 motor soon
ORIGINAL: xhaliex
ORIGINAL: d3d5
i think softer springs in the rear may help...
and os engines are greate i have a os cv-rx .18 in my rush evo. i cant get i to wheelie on command now because the wheels only slip when i go WOT and today the tires was ripped of the rims.[X(]
PA
ORIGINAL: xhaliex
ORIGINAL: d3d5
ORIGINAL: xhaliex
ORIGINAL: d3d5
no...harder rear springs. soft ones just make it squat, while hard ones pull the front end up
OH
ok thanks for all the help. But i want to get the os .18tz is there anyway i can make it so it doesn't brake the drivetrain. how fast does the cv-rx make it go? a lot more toeque to i'm guessing
ORIGINAL: jatoracing33
ORIGINAL: xhaliex
ORIGINAL: d3d5
ORIGINAL: xhaliex
ORIGINAL: d3d5
i run the .18 cvrx in my tmaxx, nitro rs4 mt, and rs4 3 evo, its a great engine and will make the front wheels easily pull off the ground, its extremly easy to tune and easy to start
OH
ORIGINAL: ehroof
i agree with the harder springs and just wanted to add another quote
ORIGINAL: xhaliex
ORIGINAL: d3d5
ORIGINAL: xhaliex
ORIGINAL: d3d5
I managed to get a couple of sweeeeeet wheelies out of my stock Firestorm yesterday [sm=shades_smile.gif]. Just played with the tune while running on tarmac.
ORIGINAL: d3d5
ok i think i've changed my mind and decided i'm going to get a os .18 cvrx when my stock engine is done for.
Just take your car out for few tanks of continuous high speed drag at WOT, bring a case of ice-cold beers on a hot sunny day, that should do it in. and you'll have reason to get that nice and shinny 18cvrx, do it do it.....
OH
ORIGINAL: ben805
ORIGINAL: d3d5
PA
if not beer then...um...fall down the steps and hit your head just take it out on the highway and never let off the throttle and youll have a brand new 18cvrx comin in the mail[8D]
80 degree should do it your lsn or idle might need adjustment, heck...no need to mess with the idle, just lean out the hsn, hammer the snob out of it on long stretch, refuel and do it again and again and again, and imagine you're driving the fast and the furious ultimate bat mobile ripping the track a new hole, hehe....you know the .18cvrx is waiting for you!!
OH
forgot to lean it out but some time this week i'm going to my lhs to get the .18tz or .18cvrx still waiting for input on wat engine will be better for the firestorm
dramatic line; NOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!
Poor little engine. but yeah, the cv-r is a great engine, it rocks with the mt. but do you really want to kill your engine? i hope your joking, if your just going to trash the engine so you can get a cv-r, then just keep the engine as a scraper or a spair engine and get a new engine to use for now.
wow, i said engine 7 times in one sentace a new record!
ORIGINAL: Shupid_one
And if you just keep your engine and get another its a geed backup.
OH
i was joking i just did like 2 high speed runs but my engine keeps stalling when i don't give it throttle what do you think the problem is not tuned or glow plug but getting new engine soon [8D]
GA
I assure you if your drive train will hold up you will not be able to keep the wheels on the ground with an OS 18 TZ in it unless you gear it way up. Once I got where my drive train would hold up on my HPI MT with and OS 18 TZ I had to gear it WAY up to keep the wheels on the ground most of the time and it is 4 wheel drive and much heavier.
