XXX-NT AD2
My Feedback: (33)
XXX-NT AD2
Hi , I`m getting back into racing 1/10 trucks and have an AD2 on the way . Was wondering if anyone has put an engine in with a sg style crank ? I know I`ll need a clutch nut for sg crank and maybe some shims , but everything else should fit . Didn`t know if it is possible to do this or not as I never tried it in the past . I have an engine I want to put in it but has sg crank . With the stock setup on a standard shaft with the long clutch nut shaft I was thinking it might be close to same length as a sg engine . I have standard shaft engines and will know for sure when the kit gets here but figured I`d ask to see if anyone has tried this .
