RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Gears
Old 10-14-2007 | 07:38 PM
Default Gears
on my gears on my jato what should i put if i dont want go too fast or too slow to get enough power ride in terrain and sand and stuff.
mORE TEETH ON WHAT THE SPUR OR THE CLUTCH.
Old 10-14-2007 | 08:39 PM
Default RE: Gears
Smaller clutch = more low end
Bigger clutch = more top end
bigger spur = more low end
smaller spur = more top end
What do you want more top speed or more low end torque. You cant do both. If you want good off road then change the tires. You can play with the gears till you turn blue and it wont matter off road. Go with some Moabs, Mashers or Yokohamas for off road.
Old 10-14-2007 | 08:45 PM
Default RE: Gears
thanks u explained it perfectly so im try low end of road and and top end on road.
Old 10-14-2007 | 08:47 PM
Default RE: Gears
Yes. But with stock tires it wont matter because it still wont move good.
Old 10-14-2007 | 08:58 PM
Default RE: Gears
here is the jato thread http://www.rcuniverse.com/forum/m_2913862/tm.htm
Default RE: Gears
I know man im change the tires for street and have some other ones for dirt.
