jato 3.3
MO
jato 3.3
If I were to get a jato 3.3, what do you guys think i should not keep stock. The tires, I will probably get geolanders and the rims, but somebody said to get rpm arms and a wide bumper too.
Thank you.
Thank you.
RE: jato 3.3
RPM front a arms and rpm wide front bumper. If you get those things it will be a monster. Not that the a arms are weak but with the speed of the Jato you ARE going to hit something at some point and thats the first thing that will break. The bumper is just more added protection. Its a great truck. You will like it once you get the different tires on.
MO
RE: jato 3.3
Thank you.
So i should get rpm front a arms and an rpm wide front bumper and then the tires and rims and it should be a beast and ill be good. right?
MO
RE: jato 3.3
ok..............if im going to be mostly running my car on dirt but i might run it on pavment and grass, what would be the best tire out of the
geolandars, dirt hawgs, and the dirt works?
