View Poll Results: A poll
Toki .18 W/ Pullstart
0
0%
Xtm .18
0
0%
OS .18 CVR-X
0
0%
OS .15 CV-X
0
0%
OS .15 CVR-X
0
0%
Voters: 0. You may not vote on this poll
Evader ST Engines!
as some of you know i just won an evader on Ebay
i look to replace the engine with one that is great for bashing and just speed
i will be buying the engine off of ebay or tower hobbies.
suggest any others if you want.
also what fits into the evader
like rotary carb or slide
short or stnd crankshaft
rear or side exhaust
Thanks!
Oh and my budget is 110$
also if any of these stated in the poll dont work with the
stock pipe feel free to suggest pipes also
Thanks!
I also have a evader st. I bought a very powerful nova rosi .12, went through the effort of converting to a pull carb, and now have the stock motor back in. I put the .12 in my onroad car. For what I do, go out and jump and bash, ect, the stock motor is fine. All the motor did was add more wheel spin or wheelies and made it more of a pain to drive. The gearing only allows it to go so fast. It was faster because the nova rossi spun higher rps's, but only really noticeable on pavement. My advice, buy rear tires, best improvement I made.
do you need the special plugs?
also will any .12 .15 .18 engine fit?
or does it have 2 be side/ rear exhaust
slide/rotary carb
crankshaft?
i plan on using the stock pipe
also which bodies will fit the evader st
will nitro rustler bodies fit
xxxnt?
rc10gt2?
thanks!
EDIT!
also which tires/wheels fit
i was thinkin of getting some proline 2.2's but i dont know
if i get the ones for the
xxxnt
rustler/jato/stampede
rc10gt2
i know the NEST uses crospins in the rear and holds bearings in the front
but which one works
also
will any proline2.2 tire fit on any proline2.2 rim
thanks
slide/rotary carb
crankshaft?
xxxnt?
rc10gt2?
thanks!
EDIT!
xxxnt
rc10gt2
but which one works
also
thanks
My Feedback: (33)
Any .12 , .15 or .18 will have the same mounting requirements so you can use whichever you decide to use . Neither of those bodies will fit and you should use a body that is made for that truck . As for side or rear exhaust , sure your stock pipe and header are for side exhaust . Your truck is set up to use rotary style carbs , but sure you can get a different servo horn and make it work for a slide carb . You need a threaded crank engine for your truck with a rotary carb with side exhaust . But you can get a different header/pipe and different servo horn to go with a rear exhaust slide carb engine if you want to .
"will any proline2.2 tire fit on any proline2.2 rim" yes
Losi Truck rims or Proline rims for XXX-t or NT will fit on the rear and the front .
