RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
gear ratio help
Old 01-16-2008 | 08:15 PM
Default gear ratio help
can ne1 suggest wut gear ratios i can use to get good performance for bashing my rc10gt in the streets and park..
what clutch bell shud i use and the size of my spur gear i shud use???thanx guy
Old 01-16-2008 | 10:05 PM
MJAsony2305@aol.com's Avatar
Default RE: gear ratio help
22t clutch bell and a 72t is what i got on my nitro rusty so if they are similar i would run that.
Old 01-17-2008 | 10:57 AM
The ratio he is telling you won't work the same on your car b/c your dif gear ratio is different. I suggest an 18 / 58 combo you need to get the spur gear for a team assosiated Nitro DS. I've used every combo from 15/66 to 24/54 and the 18/58 with an .18 engine is a very quick combo. I can't remember off hand but im pretty sure i used a 17/60 combo to hit 54 mph and it had crazy take off.. The 24/54 combo was very slow off the line but at half speed the tires turned into pizza cutters and had a tendency to go on two wheels sideways. With the 17/64 it couldn't stop wheelieing coming out of corners and i lost a race b/c of it to another rc10gt but we both beat the jato 3.3 and so I changed to the 18/58. If your using an OS .18 cv-r you should be able to stay with a jato 3.3 on a 100meter oval.
I hope this helps.
O.K.
Old 01-17-2008 | 06:57 PM
i am running a ox max 12
Old 01-17-2008 | 07:29 PM
Yah that ratio should work good it wont spin out on the pavement but it will go lots faster...
Old 01-18-2008 | 03:02 PM
so i shud run a 18 / 58 combo with my os max .12
Old 01-18-2008 | 09:17 PM
For bashing why not you'll get some nice top speed around 45+mph and good takeoff.. I used a 17/60 combo to clear triple jumps at my local 1/8th scale buggy track..
