RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
speed for jato
Old 01-23-2008 | 12:13 AM
Default speed for jato
[8D]what would make my 3.3 jato to go even faster could you guys give me some gearing options and tips to make it lighter? and maybe suggest a better motor too thanks[8D]
Old 01-23-2008 | 06:10 PM
MJAsony2305@aol.com's Avatar
Default RE: speed for jato
get a MACH 427 and if u just wanna go fast and do no bashing get carbon fiber everything also get a dual exhaust as for gearing thats for you to experiment with.
Old 01-23-2008 | 07:58 PM
dual rear exhaust. here is the link............................................[link=http://www.rdlogics.com/cgi-bin/category.cgi?item=61940P&type=store]clicky[/link]
Old 01-23-2008 | 10:16 PM
hey i tried that dual pipe and it dosent really work rb tuned pipe or sumthing or even traxxas's pipe i thought those worked better
Old 01-23-2008 | 10:32 PM
what was wrong with the pipe. it increases my speed by 5-7 mph. IT ROCKS.
Old 01-23-2008 | 11:37 PM
i dont need the dual rear exhaust. if you take the header off the motor rotate it 180 degrees so that its facing backwards all you have to do is put the pipe back on and secure it to one of the holes in the rear shock tower. now you have a rear exhaust system for the jato... its probbably kinda hard to understand but i will try to load a picture up soon to show you guuys
Old 01-24-2008 | 12:26 AM
it is not as good as a dual rear exhaust. the resonator is plain and stock.
Old 01-24-2008 | 10:47 PM
naw i have the chrome high power resnator and its fine
Old 01-25-2008 | 01:38 PM
o.s. .18tz
Old 01-25-2008 | 04:07 PM
yah an OS .18 tz will make it faster
Old 01-25-2008 | 04:34 PM
ORIGINAL: cool rc cars
if dual exhaust pipes actually added performance, why are there NONE used on high performance dirt bikes?
2 strokes make their best power with a single tuned pipe, dual pipes don't perform as well, but some think that they look better
Old 01-25-2008 | 06:05 PM
that is a dirt bike. it would not fit on dirtbike. + i never see the best motorcycle out ther, harley, with out a dual pipe. any way not about bikes. this is a tiny machine little things make a difference.
Old 01-25-2008 | 06:13 PM
yeh thats true but i think it does make it better i saw improvement when i upgraded to a resonator from stock so i think a duel would help just my .02
Old 01-25-2008 | 06:29 PM
street bikes are 4 stroke motors
dirt bikes can be 2 or 4 stroke motors
a 2 stroke motor is very sensitive to exhaust design, and needs a tuned pipe to make good power
4 stroke engines aren't as sensitive to exhaust design because there is an exhaust stroke to push the burnt gases out.
while a dual pipe may look cool, and is fine on a 4 stroke engine, it hurts performance for the sake of style compared to a good tuned pipe on a 2 stroke engine
http://www.motorcycle.com/how-to/how...care-3423.html
that link is a good read as to why 2 stoke engines need a tuned pipe
Old 01-25-2008 | 07:19 PM
but a rc car engine is different than that granite i don't like the dual exhaust cuz my resonator works just fine but if it didn't increase performance why would traxxas put it stock on the stampede which might i ad is a very good reliable truck
Old 01-25-2008 | 07:35 PM
o.s. .18tz was clocked in my jato at 77
Old 01-25-2008 | 08:13 PM
Whell, I think that 20/40 gearing is a must on the jato. It slows down the acceleration to something you can handle alot easyer. To lighten it you should get a pull or roto start, remove the role bar, remove the mud flaps, carbon fiber chassis if you want. For top speed you will want 1/8 foams (you will need 17mm hex adapters). For engines you will want the os 21tm or the sirio S23RE .23 (both have pretty high rpms)
links:
20t cb http://www3.towerhobbies.com/cgi-bin...?&I=LXPWF4&P=7 (this is 10 more than normal cbs but it is the only one that will work)
40t spur http://www3.towerhobbies.com/cgi-bin...&I=LXHFR6&P=ML
pull start http://www3.towerhobbies.com/cgi-bin...?&I=LXDGG4&P=M
roto start http://www3.towerhobbies.com/cgi-bin...?&I=LXEVM9&P=7
cf chassis http://cgi.ebay.com/Traxxas-JATO-BLA...QQcmdZViewItem (I have it and it is awesome)
foam tires http://www3.towerhobbies.com/cgi-bin...?&I=LXKKF5&P=7
17mm hex adapters http://www.neweramodels.com/item.cgi...d&part_id=3244
os 21tm http://www3.towerhobbies.com/cgi-bin...&I=LXRTM1&P=ML
or Sirio S23RE .23 http://www.amainhobbies.com/product_...ducts_id/18963
Oh yea you will also need a new header for those engines http://www3.towerhobbies.com/cgi-bin...?&I=LXFBA0&P=7
Old 01-25-2008 | 08:29 PM
ORIGINAL: [email protected]
basic principles of physics and fluid dynamics do not change on scale in this case
any 2 stroke engine performs better with a tuned pipe (which a dual is not)
the stampede has a dual, because if you're into high performance a stampede is the farthest thing from your mind
in the case of a stampede, style trumped performance
take a look at any of traxxas or anyone's high end nitro cars, and NONE of them come with a dual exhaust
Old 01-26-2008 | 04:53 PM
yeh i guess ur right but the stampede does perform somewhat well for a .15 engine
Old 01-26-2008 | 07:13 PM
scottywilkes's Avatar
replace the crappy rear exhaust with a nice small block side pipe on the stampede, and it increases the power immensly
Old 01-26-2008 | 07:59 PM
i don't have one NE more [sm=cry_smile.gif]I now have a trx2.5 rustler so its all good but hey can you check my post about poor performance and tell me whats wrong w/ my car???
Old 01-27-2008 | 11:38 AM
J8to33,
Is that sirio S23RE a drop in motor on the jato stock chassis? I know it comes with a motor mount for the revo; however, do the holes on the engine match up with the stock engine mount on the jato? I know the OS .21TM is a perfect fit with the stock motor mount. I never hear anything about the .23 sirio motor in jatos on the forums. Most people talk about the OS .18TM, .21TM, TRX 3.3 or big blocks with the New Era conversion chassis.
Mike
Old 01-27-2008 | 12:36 PM
ORIGINAL: Mspeed
J8to33,
Mike
It says that the sirio it is a drop in engine but it really isn't, whell not for the jato. But the 21tm is. I am going to get the 21tm when my 3.3 dies, whell my piston is black and the rod is red. I don't think I have much life left for this engine. Great, I need to come up with money to get it. Oh whell hopefully the 3.3 will last till the summer.
Old 05-13-2008 | 10:23 PM
http://monster.traxxas.com/showpost....1&postcount=52
it should go about 93 after u do this. it costs under 1000 dallors
Old 05-13-2008 | 10:31 PM
to make it lighter you could get rpm A-arms in front and back. and ou could also drop the eazy start and go with a pull start. hope that helps you
