huge jato problem need feedback!
MA
hi, my jato is haveing trouble starting, i unclogged the carb and it started once,and now when i try to start it all i hear
is the spinning sound of the ez start motor, almost like theres no compression....and it also has troublt idleing, when it does start
i think its the motor which i need a new piston and sleeve, but also my local hobby shop told me to check the muffler, because air comesout but it doesnt make a "puffing noise" like it should.I already tried new fuel lines,and glow plug, niether worked
What now??? =/
What now??? =/
ORIGINAL: rclynx
Traxxas exchange program is to inexpensive to overhaul one.....................go to your LHS or deal with Traxxas on line[:-]
NJ
If the easy start is turning and the motor isn't check the one way bearing in the easy start. I've had them go bad with no warning and it's a cheap as fix.
