Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Nitro Stadium Trucks
 carb keeps plugging up how to clean >
RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Old 04-01-2008 | 05:59 PM
Default carb keeps plugging up how to clean
hey guys i have a jato 3.3 broke it in as recomeded through traxas thiss year anyhow its been a good runner when i get it running . after i store a couple days the carb plugs up what i mean is i plug the exhaust tip wait to see fuel move and eventualy pull out the high speed needle to flush it . it works but this sucks i got a mouthfull of fuel today [:'(] . what do you think about carb cleaner for cars will this work. i use wildcat 15%nitro 16% oil 80syn 20 cast.
Old 04-01-2008 | 07:11 PM
MJAsony2305@aol.com's Avatar
Default RE: carb keeps plugging up how to clean
just buy a fuel filter and then no worries mate.
Old 04-01-2008 | 07:57 PM
NitroNate's Avatar
You should use 20% Nitro with 8% oil.
Old 04-01-2008 | 11:00 PM
I have had my carb get pluged up on a few rare occations. Here is what I do, get a larger fuel line that will connect to your fuel bottle and with fuel in the bottle connect the bottle to your carb and just squeeze the fuel throw the carb. I have a inline fuel filter so its every easy for me to just disconnect the line at the filter and connect my fuel hose to it. My fuel hose is connected right to my bottle at all times with two zip ties and I just put the small rubber cap on the end of the line when I am done, this way if I ever get that clog or need to prime its very quick and easy to do.
Old 04-02-2008 | 05:46 PM
hey guys thanks for the advice, as for changing fuel % etc i bought a case at 16$ a gallon and will have to make this fuel work. i have not had any problems with my tc31 carb doing this or my bj26 boats. as for the fuel filter i will try one soon but i keep a clean truck and dont run in mud so i no its not contamination . and the self primer, great idea will definatly work better than a mouth full of fuel, hopefully i dont go blind. anyhow the carb still has junk in it because my hsn is 4.5 turns out, and i no its cold and they tend to run richer for better results. what do you guys think, and will carb cleaner remove exess gel or oil. A lot of my friends say that this is not common problem, but it has been a problem ever since i broke it in during the cold winter months,I allways try to empty tanks completely so that i would not have this problem it worked well with the boats Thanks again for the helpful ideas .
Old 04-02-2008 | 09:47 PM
avg_joe's Avatar
I would be careful using anything like carb cleaner...It's got some pretty nasty chemicals in it that could eat away seals.
Denatured alcohol breaks up fuel goo pretty readily, as does WD-40.
