RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Official Traxxas Jato 3.3 Thread
Old 02-18-2015, 06:48 AM
  #1251
mattster1971
mattster1971's Avatar
Traxxas makes disposable cars. They design those gears to shred over a period of time. They make their money off the parts market.
Old 02-18-2015, 07:14 AM
  #1252
nitro-rob
nitro-rob's Avatar
I am not trying to get into a traxxas is crap debate, I put a few gallons through mine and the spur was mint. My experience with friends of mine that have had traxxas vehicles for long periods of time and even raced (slashes) regularly with theirs with no durability issues. RC Cars break, they all do.
I've never blown a spur on any vehicle, traxxas or not, in ten years. If they are shredding your motor isn't mounted right or tight or you have thrown a clutch bearing. If its melting you have a bad clutch bearing or the slipper is too loose. If its meshed right, it will hold up. The only other issue may be stones and rocks getting in.
Old 02-18-2015, 11:05 AM
  #1253
mattster1971
I'm not going to debate either, some people never have issues, others always do. Either way, Steel gearing will always be better than plastic in my book. Won't buy another RC car if it has delrin or plastic gearing. I have adjusted the slipper three ways to sunday on my car and my sons Jato and it doesn't matter, first gear was stripping out over a short period of time inside the transmission. Slipper could be the only thing affecting this and I tried all different ways. Metal saved my soul and any more hair loss. Here is a picture of her from yesterday, With a custom hand painted body from Zeike and so many upgrades, most recent being the 17mm hub conversion.
  #1254
mattster1971
Old 02-18-2015, 02:05 PM
  #1255
nitro-rob
nitro-rob's Avatar
These are machines, unless there is a manufacturing flaw that makes some of these machines different and break easily, the half that aren't having problems are doing it right. If the gears are meshed correctly and they don't move and the bearings are good (and don't wear often), there should be no issues with the spur. The internal gear problem being persistent, maybe its a manufacturing flaw that has things misaligned? I don't think that is a known flaw on these cars. If steel worked, then cool.
Old 02-19-2015, 07:55 AM
  #1256
1QwkSport2.5r
1QwkSport2.5r's Avatar
Originally Posted by nitro-rob
You should be able to drive the hell out of your Jato all day and night for months and years with the stock plastic spur gear regardless of how powerful the engine is. If you are burning them up or breaking them then there is another unidentified problem. This is true for any RC.
I agree. The only thing that I've had trouble with in regard to spur gear longevity is getting little grains of sand that gets packed between the teeth of the spur gear. If they get picked out early enough, they don't beat up the clutchbell too badly.
Anyone know if there's anybody besides New Era that makes a big block engine mount for a Jato? I have a Ron Paris Novarossi .21 that I can't sell that I might stuff in my jato. Need an engine mount though.
Old 02-19-2015, 08:01 AM
  #1257
mattster1971
Well all I know is I have not seen them work well. I thought you had to have an ips shaft to fit traxxas.
Old 02-19-2015, 09:19 AM
  #1258
1QwkSport2.5r
I've never had a problem with plastic spur gears. Actually, I tried a steel RRP spur on a Rustler. Even with he most perfect gear mesh, it ate the clutchbell for lunch. I should have hardened and annealed the CB before installing the steel spur, but the CB package said it was hardened. Guess they were wrong. At any rate, I don't agree with steel spur gears, but that isn't to say there isn't a place for them. Buggies use them, some of most as standard equipment I guess.
No IPS shaft needed. That's why they make larger diameter flywheels and bump boxes.
Old 02-27-2015, 10:28 AM
  #1259
mattster1971
I am not talking about a spur gear being eaten, I am talking about numerous times internal gears ,not the clutch bell, not the spur, being chewed up inside. So that is why I switched to solid steel. If you have great luck with the crap plastic ones then more power to you. Has not been my experience with 2 different Jatos and I don't think at this point its user error, maybe you just run it for speed on straight runs on the pavement, who knows. I bash, not pansy around. btw, if you don't like my post, don't read it. and its clean because I keep it clean, not lazy.
ID:	2076997   Click image for larger version
Name:	jato front pic.jpg
ID:	2076998   Click image for larger version
Name:	Jato no flash.jpg
ID:	2076999   Click image for larger version
Name:	jato rear suspension.jpg
ID:	2077000   Click image for larger version
ID:	2077001   Click image for larger version
Name:	Jato top pic.jpg
Old 02-28-2015, 06:15 AM
  #1260
1QwkSport2.5r
I am not talking about a spur gear being eaten, I am talking about numerous times internal gears ,not the clutch bell, not the spur, being chewed up inside. So that is why I switched to solid steel. If you have great luck with the crap plastic ones then more power to you. Has not been my experience with 2 different Jatos and I don't think at this point its user error, maybe you just drive yours like a ***** or you run it for speed on straight runs on the pavement, who knows. I bash, not pansy around. btw, if you don't like my post, don't read it. and its clean because I keep it clean, not lazy.
Some folks are more abusive to their cars are than others are. I can understand that. Steel will take a bit more abuse than plastic surely will. Makes sense.
I appreciate your classy remarks. Total class.
Old 04-25-2015, 08:21 PM
  #1261
mdenton@supro
Hi,
I have a Jato 3.3 with the older TQ 2222. My steering is too sensitive. Is there anything I can do to rectify this?
Any help greatly appreciated.
Cheers,
Mat
Old 04-25-2015, 08:31 PM
  #1262
nitro-rob
nitro-rob's Avatar
There should be a dual rate knob that you turn that will reduce the steering throw and make it more manageable at high speeds.
Old 04-25-2015, 08:55 PM
  #1263
mdenton@supro
Thanks for that. On the older controller they don't have dual rate so I wondered if there is another way
Old 05-16-2015, 07:40 PM
  #1264
308jockey
I hate to say this but on most of my cars I've had a problem with them being too sensitive at center and I'm all over the place. My solution was to get the $29 Spektrum receivers and put my cars on a DX6-I and add a good bit of expo. they are much easier to drive. I was able to use the rx and tx I pulled in some boats applications with good results so the cost worked out. Re: the discussion about gears and materials, we have 3 JATOs, a 2.5 and a pair of 3.3s. the 2.5 has been bullet proof from that angle. We have never replaced a gear in several years of just running in a big back yard. There has been some crash damage to suspension and so on but no tranny problems, it just hauls butt! The 3.3's haven't been run as much but still no drive train issues. I'm pleased with Traxxas products generally and though we don't run cars as much as we used to we keep them ready to go for when the mood strikes.
Rick H.
Old 05-17-2015, 12:00 AM
  #1265
mdenton@supro
Thanks Rick I really appreciate that. I will give it a go and see if I can lose some of the sensitivity.
Awesome
Mat
Old 10-19-2015, 12:03 PM
  #1266
mattster1971
Added a RdLogics dual tip pipe. Only thing with this pipe is you have to keep the idle higher to keep it running. needs more pressure to idle because of exhaust its moving and back pressure. Therefore it must be slightly richer also.
ID:	2126333   Click image for larger version
Old 10-19-2015, 02:34 PM
  #1267
1QwkSport2.5r
That's a power waster right there... Looks cool, yeah.. But the engine probably runs lean on the top end because of a lack of tank pressure and the pressure waves aren't going to reverberate back to the exhaust port properly causing a power loss.. The equivalent of a Pitts muffler for an airplane.
Old 10-22-2015, 09:57 AM
  #1268
mattster1971
I have not seen any loss in power, in fact much more low end power, and top speed is just as it was prior. I just don't like the way it idles, but temps are consistent in safe range. It may not be left on year round but is fun from time to time and as you said, looks pretty darn cool.
Old 10-22-2015, 10:23 AM
  #1269
1QwkSport2.5r
How did you determine which is better or how the new setup works better? Did you use a GPS? Data logger/tachometer?
Old 10-22-2015, 10:35 AM
  #1270
mattster1971
I am using a Hitech Lynx 4s transmitter with the Proton 4 receiver, it has built in GPS and I have installed the temp sensor also. I am getting accurate temp and speed readings on every run.
