RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
jato 3.3 idle
Old 07-18-2008, 02:00 PM
monmankey91
Default jato 3.3 idle
My jato 3.3 will not idle right it just continues rolling when im off the gas. I change the idle screw but then when i retune i have the same problem.
Old 07-18-2008, 02:03 PM
Jalen
Default RE: jato 3.3 idle
you might have stripped gear. Is your engine older?
Old 07-18-2008, 02:10 PM
Jozachar
Jozachar's Avatar
check the throttle trim. set it so that the throttle servo is a far as it can go without pulling on the metal rod.
Old 07-18-2008, 02:41 PM
monmankey91
no it is new and i already set the arm like u said
Old 07-18-2008, 02:46 PM
Jalen
What happens when you hit the brakes to a complete stop then let off?
Old 07-21-2008, 12:00 PM
XxRustlinxX
XxRustlinxX's Avatar
Try taking your clutch bell off of your engine..
sounds like a slipper clutch issue
usually they melt of wear after a bit
